Anyone with a Tdi experience a diesel leak from the injection pump where it bolts to the timing cover?
I assume there's an out seal in there somewhere....
I hope it's thats all it is...MC22958 said:I thought mine was leaking too but was the return line. New line , no leak.
Should there be an O ring on that bolt? Mine just has a washer.oilburner said:If it is leaking from that O ring, chances are the advance cover, top cover, control shaft etc are going to eventually start leaking. The patch will buy you some time but I would put a seal kit in it to avoid further mess.
