41 - 49 of 49 Posts
My clutch pedal seems to stick in the fully depressed position after I've pushed it in. Is this an early indication of my master cylinder failing? I've had no loss of fluid. It feels like something is binding.
I replaced my older single spring style pedal for the newer, softer version about 2 years ago. I don't think it's the actual pedal mechanism sticking.
Just curious if anyone else has experienced this.
Thanks! Happy Turkey Day. Enjoying ours a little later in WHISKEY time zone. And no Raub, this does not mean we drink whiskey here all the time.
Discussion starter · #45 ·
Neil - sounds like your slave cylinder is not fully returning....essentially what happens is the inner cylinder wall from the master cylinder wears, contaminates fluid, which flows (downhill) to the slave cylinder. After awhile, this will also cause the wall of the SC to wear...and the piston gets 'hung up' when trying to return to it's normal position. You *may* be able to band-aid it by taking out the SC, disassembling (just pop the rubber boot off/etc), cleaning using dot4, and reassembling. Sometimes this works...but is 50/50, and really you'll want to replace the SC and upgrade the MC to avoid the same issues in the future.
Again, this is the *likely* cause...but obviously there can be other issues/factors (such as the pushrod wearing through the clutch fork or similar).
Hey Jason..
I will most likely be ordering one of your kits shortly. My Second (TRW) Clutch master just died. Rob Davis had mentioned that there is a Cast Iron Slave available as well, do you carry/source the correct Slave for a NAS 90/R380 that is cast iron? Or know the P/N for the correct one?
Also trying to get to the bottom of the need for the braided line. Is the fitting on the hard line incorrect for the Dorman master, the position incorrect, both of the above, none of the above?
Discussion starter · #48 · (Edited)
Hey Jason..
My experience is that the FTC5071 slave cylinders for the NAS 90s were all cast iron typically - this is for (2) aftermarket ones I've used, as well as a genuine unit. However, just to be safe wherever you get the SC from (Rovers North, AB, etc) just ping them in advance to verify...a quick check with a magnet and they should be able to tell you all you need to know :).
Braided stainless line, as you alluded to, is mainly since the fitting on the Dorman is different than the "end" of the factory hardline. It also allows you to loop the braided stainless toward the outside of the wing, and run it along the bulkhead, then down to the 'bulkhead union' fitting down where the SC line ties in. I can send you pics/etc if need be, just let me know.
41 - 49 of 49 Posts
