First off I have the tube style fuses (on the project list to change over to blade type soon)
All lights works as they should except brake lights (installed Led and flasher) all turn indicators work correctly etc
With head lights off everything works fine.. Ie when I press the brake both lights light up and when I release brakes they turn off
When I turn daytime running lights or headlights on the left light comes on and stays on even when I press brake or not ... the right light does not come on when I turn headlight or daytime running lights however it does light up when I press the brake...
Any thoughts ? Electrical is not my strength but I do have a multimeter and willing to learn.
Could it be the pressure switch (even though things work perfectly with head lights off)
Thanks all ... usually drive truck durning day however I don’t want a reason to be pulled over at night ...
