Okay,
Its not like I've never bleed brakes or a clutch before (Okay, is been quite a few years). Master cylinder is full, clear tubing hooked to bleed nibble on clutch slave. Bleed screw open a few turns (almost ready to fall out). No fluid when I pump the pedal...
I didn't replace the slave, just the master. Is it possible there is debris somewhere in the circuit clogging it up? Am I missing something? There is now resistance in the pedal, and the initial fluid level in the master dropped, but not dropping anymore (Actually feels like you are disengaging the clutch)..
I give up :icon_peace:If anyone has any ideas, they are much appreciated, thanks..
