What size fuse for wipers?
22K views 10 replies 4 participants last post by  jrod770
#1 ·
The fuse box cover says 10 amp. Is this correct? Seems awfully small for wiper motor
#4 ·
My dilemma is that I put a15 amp in and with the truck ignition on accessory, the wipers work fine. If I start the truck up, they work fine at idle. The minute I start to give it some gas to move, it blows the fuse. That’s why I’m asking what size should be in there. Wiper motor is brand new. Thanks for your help
#6 ·
Trace out the wiring to see if you have any shorts. Its actually a pretty easy job to remove the dash to get at the wiring loom if needed. Do you have any other add-on electrical accessories that may have been tied into the wiring system incorrectly? I personally like to strip out anything that was not factory installed...I just don't trust the wiring jobs some folks do when adding accessories.
#7 ·
#9 ·
Then it has nothing to do with the wipers. That fuse should be supplying power to the wash/wiper switch and the reverse light switch. You either have a shorted wire after the fuse or an issue in the reverse light circuit. Follow the solid green wires.
