Hey guys, just thought I'd pick your brains a little.
D90 is running real fine lately (knock on wood) but on idling, I noticed that the oil light is flickering/ faintly coming on. It doesn't show up when my foot is on the accelerator. It's idling fine and steady, as in it doesn't die on me or anything like that. If I make a sharp turn and let go of the gas... while on the turn, it flickers again but disappears when foot is back on the gas pedal.
I checked the oil level and it's right where it should be. Last oil changed was about 2700 miles ago and is religiously changed every 3K with regular dino oil. D90 is not making any weird noises other than my squeeking belt that I've had for awhile, and as I said, it's running fine. Does this indicate that the engine is oil-starved? But if the levels are fine, why would it be? A clog somewhere?
Is this a concern ($$$) or a concern ($$$)? I will try to do an oil change tonight and see if it clears the light.
Thanks in advance!
Thanks in advance!
