Need a 2 post Hydraulic lift - any guidance
5K views 15 replies 10 participants last post by  Rocky
#1 · (Edited)
Guys,
I'm getting ready to pull the trigger on a 2 post lift. first I have to pour the pad. as I understand it my ex mod 110 Tithonis should weigh in in at 6500 - 7000 lbs.
So, I'm thinking a 9000 lbs rated lift will be fine.
But there are several different brands now available - with a WIDE range in prices.
so the cheap ones include
Launch (they now have a 1 piece design for towers), Autocraft, and Tuxedo. I assume all are probably Chinese - but I don't know for sure. all could be had for under 1500 -
Greg Smith seems to be very proud of their "elite' 9000 lb lift, good price, with good reviews, but who posts those reviews? I have no idea
Further up the price line - add an extra 500 - 800 bucks is the Bendpak, I think they are good quality
then some really pricey units above that.
so anyone have any idea on suitability - I'm using the lift once a month or so, i'm just a lazy hobbyist!
PS I tried the search, and came up with all sorts of posts on lift kits, etc, but couldn't seem to hone in on the correct terms to get to a hydraulic lift discussion!
#2 ·
My extended family has been in the business for 40+ years. My uncle made a career out of making parts for other US companies before manufacturing his own. Lifts - Whip Industries Price is higher than $1,500 as they are made in USA, but good lifts. Let me know if you are interested in a price list - I'm sure I can get you a discount or even put together a group buy?
#3 ·
Wish I was at a point where I could use a group buy. Someday.
I see 24 two post choices at Whip. Which ones could be recommended for a home garage lifting a 110 with a roof rack? How much?
Thanks,
Mike & Carrie
#7 ·
I've got the Atlas (10PV I think) from Greg Smith, I bought it about 2010 and it's been trouble free. At the time I did some research and discovered that Atlas, although made in China was part of Otis Elevator.
Also had good customer service from Greg Smith.
I would recommend them.
Mike
#8 ·
In my last garage, I installed a Bendpak XPS-10 with low profile arms. If you are not worried about height then you can get one of the taller versions. I liked the clear floor feature of this model, but there is a chain on top which may limit overall vehicle height. Also, the marginal cost difference between a 9k and 10k lift was so small, I went with the overkill.
When you pour your pad pay attention to the thickness and compressive strength of the concrete since that is the only thing preventing disaster. I went with 8 inch high strength fibre reinforced concrete with re-bar. No cracks and a hammer drill still works for the holes. Also look at power nearby. You will need 220v single phase, 30 amps for most lifts.
Good luck!
#9 ·
Thanks for the help. I do have 220 near my selected site. Instead of hammer drilling in the anchors (I always worry about that much weight over time. shifting slightly back and forth. I will put in all thread bent at a 90 degree , and embed that in the concrete (I use a wooden template to make sure they are all aligned perfectly!
#12 ·
thanks for all the input guys. i was very impressed by the WHIP lifts.
Duly noted on the anchors. matching up the all thread is not a big issue, we use a wood remplate, but I was doing it with an old school guy, the way they did it back then is probably inferior to the modern anchor systems, so i will go that way.
I like 4 post lifts for storage, but I have worked under several cars on a 4 post, found it much tougher and more aggravating that working under a 2 post.
so out of the blue, my kid found someone selling a 2 post 9000 lb western lift used. She found it on Craigs list facebook - I have no idea that even existed, apparently completely separate of Craigs list, because i never saw this lift posted there.
anyway Western is made in USA here in California, and as far as I can tell has a good reputation, seems to be much more common in the professional garages, not so much hobbyist)
It was 10 years old, had new cables and tubes. I ran a big pickup up and down, worked flawlessly. So I lowballed the guy - and ended up with an 800 dollar used lift.
Unfortunately , my next project is pouring the 15 X 25 pad - I'll bring in a finishing crew for the pour, I'll set up the forms and tie the rebar myself.
#13 ·
Sounds like a screaming deal! What was the asking price?
Pictures! Lots of pictures, before, during and after.
Mike & Carrie
