So I am finally getting around to replacing the rear diff seal on my 94' D90 as it has a slow leak (LT 230/R380/300tdi if it matters). I have seen posts about "pre-load" and some that sound like you don't have to do it on later models- so I am asking before I get myself in a pickle. The steps as I understand them are:
1) drop propshaft after checking UJ
2) undo center nut (Nyloc? Bolt?)
3) pull diff flange thingy (wheel puller needed...I think)
4) pry out old seal
5) seat new seal being careful that it goes in the proper way
6) bolt back on diff flange (preload?)
7) bolt back up propshaft
8) check diff fluid level and replace any lost
Am I close?
Thanks!
4) pry out old seal
Am I close?
Thanks!
