Fuel tank skid / fuel pump / Dixon-Bate Tow Jaw
1 reading
4.2K views 18 replies 7 participants last post by  tbs78
#1 ·
Finally got this project finished a couple of weekends back. It took quite awhile and there were some setbacks along the way. It started as a project to install a Dixon-Bate tow jaw. I quickly realized that I would have to drop the tank to install the jaw, so I figured that I might as well install a new fuel tank skid while I was at it. Since I was dropping the tank, I also might as well install a new fuel pump, too.
The fuel tank skid came from Stephen Peters (safarirover). It is a great product and a good value. It is made from aluminum; I took mine to the power coaters and had it coated semi-gloss black to match the tire carrier. They did a nice job.
The first complication came when I removed the hex cap screws that hold the skid in place. They were rusty and I had neglected to hose them down with Liquid Wrench in the days leading up to the repair. When I put a wrench on one of them, the head twisted off the body of the bolt. I tried a bolt extractor, only to have that break off in there as well. I ended up grinding the entire square reinforcing plate (including broken bolt) and welding on a new plate that I cut from a piece of steel bar. Once that was welded on, I drilled and tapped it, then painted it to match the crossmember and I was back in business.
Problems continued when I tried to disconnect the fuel lines. The feed line came off without a hitch but the return line had apparently been cross-threaded by the last person to work on them. The threads stripped out and I was left with this mess:
http://www.flickr.com/photos/defender90/4784444281/in/set-72157624474481858/
After a futile search for a new set of SS fuel lines, I decided to take the "Ron-good" method. I cut the hose and line and used a short piece of flared hard line, along with some fuel-grade tubing and SS hose clamps, and spliced the line.
On a side note, if you are doing this project, you can disconnect the fuel vapor vent line (with the green connector) by bending a section of a wire coat hanger into a "U" and pressing the ends into the fitting. It comes right apart; no special tool needed.
The D-B jaw was also a pain in the ass. A few months back, I estimated the length of the bolts needed to mount the jaw and ordered some from McMaster. Once the fuel tank was out, however, I realized that I had ordered them too long. I re-measured and re-ordered, only to realize that I had neglected to factor in the thickness of my Expeditionware backing plate. Crap. I carefully measured for a third time--the proper length is 100mm, for those that are doing this project--and placed yet another McMaster order and was finally able to install my tow jaw.
For the reinstallation of the skid plate, I sourced some type 316 stainless steel hex cap screws and washers and used a liberal application of anti-seize on these.
Still, the problems continued. Everything was put back together but the truck wouldn't start. I could hear the fuel pump but it wasn't getting fuel. Another de-assembly and re-assembly later, it was determined that the fuel lines were reversed at the fuel pump. ****. Lesson learned: don't do these things late at night.
The finished product looks awesome and it was worth the sweat equity.
http://www.flickr.com/photos/defender90/4907327979/in/set-72157624474481858/
http://www.flickr.com/photos/defender90/4907919952/in/set-72157624474481858/
http://www.flickr.com/photos/defender90/4907326379/in/set-72157624474481858/
#3 ·
Nick,
You have to drain the tank (I used a Super Siphon), disconnect the fuel fill and overfill lines, disconnect the vapor vent line, disconnect the fuel lines in front of the tank, and disconnect the fuel pump electrical connector. I don't recall having to do this in any specific order. You may have to tweak the fill nozzle to get the siphon in.
#5 ·
The harness is right down there by the fuel nozzle. Not hard to get to. There's enough slack. The hardest part is disconnecting the fuel lines. Be very careful and slow. Use line wrenches. Also, it would be wise to hose the fuel skid bolts down with Liquid Wrench penetrating oil for a few days prior to pulling them off.
#6 ·
Would anyone remember the number and size of the bolts that hold the gas tank skid by any chance? I'd like to stop by tonight and buy some to reinstall the skid/tank and at least make the truck drivable.
#10 · (Edited)
Looks like I will retap everything. I checked and i have used a 10mm 1.5 pitch tap for the places where the bolts broke... Anyway, finally got stainless steel bolts last night for the reinstall. Of course there was no 30mm and not enough 25mm, so I'll make do with 20mm as well as/or 45mm that I'll likely have to cut.
#12 ·
Really? Is stainless steel just a surface treatment? Jeeze... Did not think of that, always thought this was better than zinc plated (and softer) because this was a special alloy.
#14 ·
The rusting typically occurs because you will be using a ferrous blade (assuming hacksaw or sawzall) and the particles from the blade that wear off during the cut become embedded in the SS and rust. The bolt will not rust through, just have surface rust. This is also why it is recommended that you don't use uncoated or black oxide wrenches on SS. Some people go as far as to have a dedicated kit of chrome plated wrenches just for SS (this is not me!).
Is shear strength really that much of a concern for a skid plate bolt? I know that I had the same thoughts at first which is why mine is currently installed with some class 10.9 bolts but long term I plan to countersink my skid plate holes and use some SS pan head cap screws.
Posted from my BlackBerry using BerryBlab
#16 ·
So its the residual ferrous material from the cutting disc rather than the SS that rusted...
For most SS fasteners you are replacing with a weaker fastener than what was there before. Perhaps the original bolt spec was overkill for the skid plate. I don't know/care. There seems to be a fascination with replacing fasteners with SS and I don't get it. Proper spec bolts and anti-seize seems like a better option. ymmv
#15 ·
I'm not worried for the skid plate and SS hardware. I am only mildly concerned with the stock 8.8 bolts on the front bumper since I'm using it for winching. So far so good! :) not trying to make anything overkill.
#18 ·
Fuel tank bolt questions
Hey Chris, I need to replace the gas tank on my NAS 110. Got all the parts from Zack at RN. Regarding the bolts that break off are they these in my pics? Any other ones I have to be careful with? I plan to PB blast them for about a week and tap them often too. Do you recall the party number for the as bilts from mcmasters? Do you know if anyone makes an alloy skid for the Nas 110? Thanks for your help, Eddie
#19 ·
I replaced mine on my 95 nas 90 with a galvanized one. The bolts were all m10 x 1.5 pitch. I broke off half of them and had to drill out the old bolt and retap the holes. The ones in the cross member are the hardest to access because the step bumper supports are in the way. They are also most likely to break because you can't access the threads to spray liq wrench. I bought an extra long drill bit (think it was aircraft bit) which made it workable. Slow but workable.
