ARB Question
1.4K views 1 reply 2 participants last post by  Wolf Fabrication
#1 ·
Excuse my ignorance, but I am in the process of re-installing my rear third member after replacing the pinion bearings and carrier bearings in the ARB. I hooked up the air line to the third member before installing it back into the axle housing to check for leaks and have a slight flow of air coming from the seal housing assembly until the locker is rotated in which it stops. I didn't know if that was normal or if that seal housing o-ring is faulty and causing the leak.
This is a learning process for me so thanks in advance.
Rob
#2 ·
ARB has constantly had issues with those o-rings, and depending on what year your locker is you could have one one of the older style seals that are prone to failure. Anytime I take an ARB out to do the bearings I put in a new o-ring.
I just installed two brand new ARBs and noticed the new style o-rings are much better - they have two sealing "lips" instead of being just an "o ring."
Good luck!
