Paired with ome springs (HD front, medium rears) I'm really in the fence as I redo my suspension. Right now I'm not looking at other options I have TF, and on other cars/trucks I have never been happy with bilstein.
I had this same failure on both rear nitro OME heavy duty ones in one hard day. The welds are just so small. I was at stock height and heard after those (heavy, or medium?) are really meant for a vehicle with a greater than stock height. The old OME nitros (metal body mid 2000s ones) I had on the car were fine for many years and were a bit worn but otherwise workable. Don't much like these new ones, but still have mediums on front axle and those have been abused.Reviving an old thread. I snapped a OME shock at the top mount over the weekend. After looking at the break, it appears to be a bad weld from the manufacturer. There was rust around where it sheared off. I over extended them since I didnt have any spring retainers.
Im thinking the next go around will be 2.0 Performance Series IFP. And I probably need to retain the spring as well.
