I have dents in each outer fender that I have been trying to get removed. The paintless dent folks so far won't touch them. One I can understand, the other doesn't seem that hard to fix. I've been to one auto body shop and it was pricey- even if I did the remove/replace.
The one from the right fender is hard to see, it's bent but there is no crease or paint damage. I really just want my flare to fit correctly on this fender. The left fender paint is damaged.
Any ideas on removing either of these? My initial thoughts are to remove the right outer fender and beat it from behind with a rubber mallet. Or to pull on it with the fender attached to the truck. I'm not expecting perfect results, just some improvement.
Thanks,
Alex
Thanks,
Alex
