Led lights... I know, I know
5K views 10 replies 7 participants last post by  hanzo111
#1 ·
Morning all. Recently acquired a 97 NAS 90 SW. One tail light works (dimly). Pulled it apart and the bad one has a really corroded (shot) bulb holder.
So LED brakes seem like a reasonable replacement plan.
I’ve looked around and I can only find the wipac versions that requires cutting and soldering the pigtails to the factory connector.
Anybody have a plug and play solution? Can the plug be bought separately?
Thanks all
#2 ·
#3 ·
The Bearmach BA9719 set was plug and play, but they don't seem to list it now. It's still available from a few sources if you search for it. I did have to swap around the pins on a couple lights in each set though. Not sure if that was Bearmach's or Land River's fault.
The connectors are probably available many other places, but I've bought a lot from Eastern Beaver: Econoseal
#6 ·
We carry LED lights kit (8x 73mm lights) and we also have 95mm LED lights.
LED Lights Kit - Smoke / Clear / Color - $110
LED 95mm Fog & Reverse Smoke or Red/Clear- $50
460815
