So I have the Rovertym 2" lift (it`s more like 2.5" though) and Rovertym trailing arms. There was a grind while decelerating, everyone said it was the driveshaft. So I replaced the driveshaft with a Tom Woods double cardin shaft. It still grinds. So I adjusted the trailing arms, and went from a 3/8" spacer down to a 1/8" spacer. Still grinds, but slightly less.
The low pitched grind only occurs while decelerating at speeds above 30 mph or so. Otherwise, while accelerating or holding a steady speed, it runs just fine. In fact, it runs beautifully, which leads me to believe the differential and transfer case are doing just fine (I would think if there were issue with either of those two, the problem would be more constant, not just while decelerating?).
I don`t particularly mind the grind, because the truck is running very well, and you don`t really feel it, it`s just that it sounds awful. Any input or ideas though? I just want to make sure this is normal, because i`m in the process of selling this truck, and I don`t want to pawn off a headache on somebody else (like the previous owner did for me in so many regards).
-Nathaniel
-Nathaniel
