Hello,
I have a 83 110 2.25 liter diesel that has some kind of electrical problem. The problem is the brake light, all turning lights, and both the fuel gauge and water temp gauge are not working, they all seem to run on the same 10A fuse which is good so no problem there, I have no idea what it could be. Looking at the wiring diagram none of them share a ground that I can see so I'm not sure if a bad ground could be the problem. The starter was just changed, but before I changed the starter I had to jump the wires on the starter to get it to started so I could get home, could that have been the problem? Please help as I am out of ideas.
------ Follow up post added March 4th, 2015 12:35 PM ------
Forgot to say when I jumped the starter it didn't blow the fuse, and everything work prior to starter change
