What size line wrench?
3.2K views 6 replies 4 participants last post by  andy110
#1 ·
Trying to get the lines off the rear brake cylinders on my '86 110. What size line wrench?
#7 ·
Tried a flare nut wrench, I only have standard size. Did not fit. I put a regular metric wrench on their to gauge size.
------ Follow up post added March 20th, 2013 12:45 PM ------
Hm well it may be 7/16ths then. IIRC, the fittings are 3/8-28 straight with DIN flare. However some are 10mm metric, so that was my first guess. If it is chewed up I can make you another pipe with new nuts if you send me the length. Don't try to save questionable brake parts.
At this point I do not mind cutting the lines to get the cylinders off. I replaced the front lines, might as well replace the rear as well. Thanks for the offer, I can bend up a set myself:)
#5 ·
