Trying to get the lines off the rear brake cylinders on my '86 110. What size line wrench?
At this point I do not mind cutting the lines to get the cylinders off. I replaced the front lines, might as well replace the rear as well. Thanks for the offer, I can bend up a set myselfHm well it may be 7/16ths then. IIRC, the fittings are 3/8-28 straight with DIN flare. However some are 10mm metric, so that was my first guess. If it is chewed up I can make you another pipe with new nuts if you send me the length. Don't try to save questionable brake parts.
