Replacement Footwell Trim Panels - Page 4 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old April 16th, 2010, 09:24 AM
Guys afaik you can just go to his site and order them. He has them in stock and the drivers side only differ between auto and manual.
http://www.safaridust.com/Footwell-T...ns-SD51894.htm
Tom it looks like there is something screwy with your site. The page above for the manual trans driver side has confusing wording about the package containing a auto drivers side and a early no ac passenger side, neither of which I believe are relevant
Old April 16th, 2010, 09:29 AM
Ordered last night!
Old April 17th, 2010, 07:50 PM
Frank84
Frank Battersby
95 D90
I've had mine for a few weeks - great piece!
'95 Soft Top
'89 Classic Tdi
Old April 18th, 2010, 10:44 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Thanks Charles, just fixed that....sorry for the late response.
Those that just ordered, part will ship out Tuesday...
Joshua, take a photo on passenger side with details on mount points if possible.
Tom
Old April 19th, 2010, 03:07 AM
bd90
94 Arles Blue #1644
Would like Driver and Pass side for a '94 with AC. Not sure about the cutouts. need to take a look at it. When might that be available?
Also, whats the ETA on the binnacle for instruemnt cluster? Shows currently out of stock.
Also, do you have some more/better pics of the Heritage Grill? Is the Heritage Grill your design or is it a copy of an existing grill? Im not that familiar with the history on that part.
Old April 19th, 2010, 11:05 AM
moondog
philip mooney
1994 d-90
'94 d-90 manual 5 speed
i am interested in both the passenger and drivers side. are they avail ? thanks
Old April 20th, 2010, 07:24 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Guys, drivers side is available...passenger side with AC currently is not.
The "Heritage Grill" is a Land Rover part...it comes WITHOUT the Land Rover badge on it...have many in stock.
ID:	26813   Click image for larger version
Old April 20th, 2010, 07:34 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Footwell Panel How-To Install Pic
Old April 20th, 2010, 08:57 AM
moondog
philip mooney
1994 d-90
how about passenger side without ac ?
Old April 20th, 2010, 09:11 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
yes, we have in stock...you can select from the different styles available...
http://www.safaridust.com/Defender-Footwells_c2.htm
Old April 24th, 2010, 12:18 PM
Brenter
TB
2005 RR HSE -SOLD, 1987 110- SOLD
Do you have any passenger side footwells that have a cut out for hood release?
Thanks In advance
Old April 26th, 2010, 02:20 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Thanks In advance
Yes we do:
Item #: SD51895
http://safaridust.com/Defender-90-11...AC-SD51895.htm
Old June 2nd, 2011, 07:53 PM
Why is this such a pain in the ass to install??! I can't f'ing get it and now the thing is mangled. What does it secure to up top, and is it otherwise installed correctly toward the pedals?
I bought this the first week I bought the truck, half-ass attempted to install 3 times, was determined this time, but nothing but frustrated.
Getting it around the pedals is the easy part, how about a little more insight?
ID:	39305   Click image for larger version
ID:	39307   Click image for larger version
Old June 2nd, 2011, 08:17 PM
It fully interferes with being able to open and close the door.
ID:	39316   Click image for larger version
Old June 2nd, 2011, 08:48 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
Josh your whining suck it up! JK
Its hard to tell from the cell phone pic's but it looks like your missing the trim piece that holds the top up. Look at the last pic on this page.
http://www.ecr4x4.com/Defenderfootwell.html
------ Follow up post added June 2nd, 2011 07:52 PM ------
Try tucking the top in between the closure and the bulkhead first before putting the bottom in.
Old June 2nd, 2011, 09:29 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Josh, pretty sure that you are going to have to trim out for your door arm. In my '94 I didn't have this problem. In this pic you can sorta see how I mounted mine. I used the small piece of angle trim that is held in with a few of the steering column surround screws and then used the tabs at the bottom...worked great!
ID:	39320   Click image for larger version
Old June 2nd, 2011, 09:42 PM
Is it because I have A/C? Mine is all scratched up now, too because of having to try this multiple times. Freaking sucks.
------ Follow up post added June 2nd, 2011 09:44 PM ------
Also, why is your clutch arm so much thicker than mine?
Old June 2nd, 2011, 11:11 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
You gotta love the consistency of these trucks. I bet none of them are exactly the same.
Old June 2nd, 2011, 11:12 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I am not sure how A/C would affect it but I assume it could cause some issues. if it is all scratched up, pick up a can of the Rustoleum bed liner spray and use that from about 6" away. don't know why the difference in clutch arm...as far as I know that is the stock arm in my truck.
looking at Tom's site it looks like most of his panels are listed for non-AC vehicles. you may want to talk to him about what is necessary for fitment or if he has other panels that will work better
Old June 2nd, 2011, 11:49 PM
bjf's Avatar
bjf
barry f
94 ST #395
Horsey
You will have to cut. It looks like the panels you have are for a 94 not a 95. Also as James said do you have the trim sttrip at the top? If so remove it, install kick panel then put it back in.
Also your clutch is weird. Never seen such a thin arm in defender. Hope you dont snap it under your massive legs
ac, defender, footwell, panels, replacement
Used D90 Interior Trim Panels Wanted Manimal Wanted 5 January 4th, 2010 06:16 AM
Metal footwell trim / finishers cabell Wanted 3 January 6th, 2009 08:20 PM
Footwell Trim Replacement 61rover Defender Technical Discussions 10 November 20th, 2007 12:57 AM
Defender footwell trim mattarm Wanted 0 June 19th, 2007 01:07 AM
How to ship lasalle headliner and SW trim panels? Chris Cox Defender Technical Discussions 4 March 23rd, 2005 08:07 AM
