1 - 9 of 9 Posts
Will be converting a Rover 4.0 EFI V8 to carburetor and looking for the following parts:
1. Intake manifold & carbs. (4 barrel or twin SU)
2. Front timing chain cover for distributor (HRC 1321)
3. Distributor
Any parts or leads would be appreciated.
Frank
Frank is that wobble drive or soild? Got both non-wobble
Can you please educate me as I am not certain what a wobble drive or solid is with reference to.
I thought I could swap the 4.0 timing chain cover and camshaft, from a 3.5 or 3.9, to convert the coil pack engine to a traditional distributor.
Frank
You should go Holley Sniper.
question is how old school do you want to go? points and condensers or electronic
3. Distributor
Frank
I have two take off SU carbs from a 1989 3.5 V8, only had 60k mi on them. They are super clean but a few items have been removed to donate, One butterfly flap and shaft, one float, and maybe one spring. I can send photos later this week. Yours for $100 plus the ride.
I might have an intake manifold, will check.
1 - 9 of 9 Posts
