1 - 2 of 2 Posts
I am in the process of sorting the wiring for my 4.2L conversion in my '86 110. I salvaged the complete wiring harness from a 1994 RRC LWB and have just started to disassemble it. This may be a long shot, but does anyone know what type of connection this is? There looks to be quite a few of these connections throughout the harness. It is located close to a snap connection that ultimately should lead me to the starter relay that I need to remove and keep, but I can't without first separating the connection that's pictured. Small black wires look like grounding wires to me. What do you think?
If it is a solid black wire it is just a splice for a series of grounds. LR did this type of thing in the harnesses. You will find them on other wires too. I have seen some that have a type of goo inside the tape and others that have a crimp connector. Pretty common.
1 - 2 of 2 Posts
