1 - 2 of 2 Posts
I got my plug for my wiper motor and I'm trying to line it up with my switch. I could only find one diagram that labels the plug connectors but I'm not sure it's right since none of my wires seem to match. I'm assuming first speed means low and second means high??? My switch has intermittent built into it so I don't have a relay. I was actually thinking I should have a relay between the switch and motor but I'm still trying to figure that one out as well, I was thinking low on pin 87 and high on 87a on a 5 pin relay but not sure about that either.
I guess what I really need is the motor plug wires orientation for now and if you have more input, I'm all ears. I really don't want to BBQ all this by testing it out without any idea.
Thanks,
Sean
Discussion Starter #2
I've found some more pictures but not much specific to Defenders. I did see mention from a post in 2004 that said:
Red-low speed
Yellow-high speed
Blue-ground
This matches the diagrams and my motor wiring so I'm going to go with that. I'll try to confirm this before I move on.
Sean
1 - 2 of 2 Posts
