1 - 9 of 9 Posts
Try jiggling the parking brake lever to see if you can get it to turn off or at least flicker. Typically that means the switch on the brake lever is bad or has a poor connection.
-Ash
So we are talking about warning light "D" or "E" or both?
"E" looks super easy. Looks like yellow no trace and goes only to the side of the handbrake.
"D" looks like it gets power from the ignition white/ red trace wire and then to the brake check relay (I don't have a clue what or where that is) brake fluid loss, I'm guessing, is at the MC on the Black wire/ white trace?
Could be a PDWA of you have one. Look for a block that joins the front and rear brake lines with a wire coming from it.
1 - 9 of 9 Posts
