1 - 18 of 18 Posts
Land Rover Discovery 1 Steel wheel - $50
Salisbury axle - $200
(2) Interco SSR Super Swamper 35x10/16 - $50 each
EGT Probe and gauge - The Sensor Connection EGT Probes Motorsports Sensors and Gauges - $50
RTE 1st Gen adjustable shock towers - galvanized - $150
Steering Shaft - RN - new in plastic - $65
Fuel separator - $50
Blue Sea Safety Hub 150 Fuse Block - $70
110 Sliders - galvanized - $250
90 Springs - HD fronts - $100 pair
Rear Trailing Arms - galvanized - $50
1986 LRD RHD 110
Hello There
how much for the
AMR3307 is that the fuse in the battery box compartment?
Discussion Starter · #11 ·
Slider pics - I have the brackets too and some M12 bolts. Threads would have to be chased from the galvy but I can buy a tap and do it as well.
Discussion Starter · #12 ·
Any reason that steering shaft would not work on a NAS truck?
I think it should work. I bought it for a friends 200tdi Disco install but he was able to use the original steering shaft. These shafts are the later style ones and I believe the same length end to end.
1969 Ser IIA 300 tdi Hybrid,
sent PM
Discussion Starter · #16 · (Edited)
SOLD - Steering Shaft
PENDING - Salsbury Axle
PENDING - Rear Trailing Arms
PENDING - AMR3307 Fuse Box
PENDING - RTE 1st Gen adjustable shock towers
NRC5742 - RH - galvanized and powder coated - $75
NRC5742 - RH - just painted - $50
NRC5743 - LH - needs paint - $50
Accelerator Pedal assembly - NRC7827, NRC5220, LHD 200tdi cable - $60
Brackets - frame to bulkhead - galvanized and powder coated - $25
Lower front spring retainers - galvanized and powder coated - $20 - Front Spring Retainers, Hook Type, GL1054 – GwynLewis4x4.co.uk
Discussion Starter · #18 ·
SOLD - RTE 1st Gen adjustable shock towers
SOLD - AMR3307 Fuse Box
1 - 18 of 18 Posts
