There is no relay. It goes straight through the switch. Probably the how low switch. They like to go bad. Adding relays is a good idea to prevent future switch failures.
The relay is just to turn the lights off with the ignition. It is not a typical light relay that takes the power off of the switches.Will, I replaced the high/low switch and it still does not work. There appears to be a relay on my truck for standard beams - you can certainly hear/feel it clicking when you turn highlights on.
Thanks
Where was the wiring wrong, at the light plug, or at the switch ?I had a similar experience when I rewired my headlamps. My issue was I had the low and high beam wires switched. I needed to make custom connectors for my replacement LEDs so I was not protected from myself. With wires switched I got low on low and low on high. Wired correctly and everything worked as expected.
Thanks for this, very helpfulMine was wrong at the light plug. My front light harness connectors (headlights, parking and turn signals) are all custom due to switching over to LED and I had the wires crossed at the connector.
