1 - 17 of 17 Posts
Hi All,
I have been struggling for a week now trying to figure out why my turn signals flash rapidly. All four bulbs are working. The hazard lights work just fine. Any suggestions on how to trouble shoot this?
Thanks in advance.
A quick flash indicates less resistance in the system, thus a bulb being out. (or less resistance from using LED bulbs) If all three lights are working on each side then I would zero in on the flasher, however it still could be a ground as mentioned above. Have a look at the hazard switch also making sure both wires on the back side, as well as the main connector, are making a good contact. Once you have checked those things and you still have the problem it may be in the turn signal itself.
Boy, you guys are fast!
To give everyone a more complete picture...
- Bulbs are conventional
- All four bulbs are working
- The indicator light on the dash is working
- Being that this is an AA Yellow D90, I have no problems getting other driver's attention :)
Thanks again for all the help.
------ Follow up post added June 19th, 2015 08:08 AM ------
Dave - when you say "the flasher is about to die", do you mean the hazard unit on the dash? The relay? Something else?
There are 7 bulbs in the flasher system - 4 corners, 2 repeaters, 1 indicator in dash
most likely the hazard switch is the culprit, pull off, contact cleaner and reinstall
next candidate is the flasher relay - same treatment as above (then replace)
Discussion Starter · #12 ·
I've only had the truck for about three weeks and it has always been this way. The side markers have bulbs in them and come on when I put the lights on. I replaced the right rear side marker wiring harness because the one that was in there was corroded and didn't work. None of the side marker lights worked when I got the truck but after removing all the bulbs and spraying the connections with WD-40, they came back to life.
Harness is then likely wired for the bumper repeaters 1995 NAS 90?
- there are a few options to fix.
1. Add repeaters (swap marker-light circuit with turn-signal circuit into sidelights up front or install into bumper if still in place)
2. Add resistors (plug into repeater circuit on both sides)
3. Swap to a flasher relay with potentiometer (IE adjustable relay like used in LED application)
Discussion Starter · #17 ·
It used to have an ARB front bumper with the blinkers in it - are they still wired?
Hey Josh - the front bumper doesn't have any allowance for repeaters... as far as I can tell, the wires for the repeaters have been cut (red/orange and black). I am thinking that this would essentially create infinit resistance and the system would think a bulb was out. I put a resistor on them but that didn't solve the fast blinking. Is there anything else you can suggest? FYI, I did take the connectors apart on the hazard switch and clean them.
1 - 17 of 17 Posts
