Thanks...in the process of designing and building a d90. Will do all the interior soundproofing available. Just was wondering if someone at Kahan, twisted, arkonik etc sourced some better sound insulating glass for the higher end builds.With hinge brackets, the gap between bonnet and bulkhead, the lip on roof above windscreen, and that fact that it is an uninsulated aluminum brick I think that noise may be a feature you either learn to live with and mitigate with sound dampening materials or buy a Lexus.
Have you dynamatted the floors, seatbox, bulkhead including pulling dash, inside doors, etc? Dynaliner on inside of bonnet and on roof? Added Wright Offroad matting or carpet? All are proven methods to lower sound/resonance.
I was not interested in changing the outside look of the truck. It is iconic but understand the limitations with noise given its design. I am not going to go overboard and redesign the glass and seals to get a marginal reduction in drivetrain and wind noise. It is avaaible on the Macan as an option even thought the car is very well insulated already. I do understand from other owners that it makes a substantial difference so was just wondering if someone had already attempted to do something similar with the Defender glazing.If you are going ground up, the bulkhead, tunnel, seatbox and floor panels can be thermal coated and insulated/sound dampened.
Other than that, there are a ton of sharp edges, drip rails, and protrusions that would need to be overcome. Again, any old school hotrod shop could smooth these away, but that would be pricey and IMO kind of be an abomination on a Defender. :rolleyes. Opinion only.
Take a close look at a JK Wrangler or newer G-wagen. The windscreen in particular on Wranglers does not present anywhere near the sharp edges and impediment to good aerodynamics.
I have a 2013 Puma that has been DynaMatt’ed on the tub floors, sides, and footwells. Has factory carpet and insulation pads. Full headliner. Still a noisy beast. Not 1990’s 300Tdi noisy, but noisy.
Also have a 1994 300Tdi, dynamatted on roof, tub floor and sides, footwells, tunnel, rear bulkhead behind seats. Cab only headliner. Factory matting. Can have conversations at 60MPH, but it requires speaking louder than normal.
My experiences are in no way scientific, but based on real world hit or miss attempts to save my hearing!
Great white paper . I wasn't sure thicker was the answer but the article clearly makes sense. I don't know the process of cutting custom glass but the defender looks pretty straight forward if this is reasonably economically possible.Cool topic. My 2015 (WK2) Grand Cherokee diesel has acoustic glass, and it is surprisingly quiet in the cabin. It's a combination of many things, but from others that have rode in both w/ and w/o glass, it's worth having. That said, it's not just thicker, there is obviously some science behind it. Im sure someone has acoustic glass stock somewhere and could cut to size.
Here's a cool whitepaper about the glass and earlier CRD jeeps.
I hate to burst your bubble, but my front windows are 3/16" (4.7625mm) and I still wear earplugs when I drive my truck.
Feel free to spend your money however you like, but have you done all the other sound deadening work?
Complete exmoor molded mat setup, headliner, rear rubber mat and carpeting, etc?
Very Cool, I had no idea this existed in the automotive world.Cool topic. My 2015 (WK2) Grand Cherokee diesel has acoustic glass, and it is surprisingly quiet in the cabin. It's a combination of many things, but from others that have rode in both w/ and w/o glass, it's worth having. That said, it's not just thicker, there is obviously some science behind it. Im sure someone has acoustic glass stock somewhere and could cut to size.
A defender is nothing but a road legal farm tractor, personally I could never live with all the little idiosyncratic issues specially at the astronomical cost of acquisition.
no mater what you do with it, the truck will be noisy, drafty, slow, leaky too cols in winter, too hot in summer and to me uncomfortable driving position. ( have seen two guys dropping nearly 100K in noise suppression upgrades with unsatisfied marginal results).
I would say the wheel has been round for ages, no use in redesigning it.
best of luck reaching your goal.
