1 - 5 of 5 Posts
i'm trying to get the trany on my 97 d-90 unbolted and seperated from my engine... apparently easier said than done.
well, I thought I would list everything I have disconected in hopes that someone could let me know there is something else I haven't done.
so here it goes:
all cooler/hoses/pipes/etc
all electrical
9 bolts securing bell housing closing plate
3 bolts securing bell housing access plate
4 bolts securing drive plate to converter
RH and LH mounting to chassis brackets
8 bolts that connect tranny to engine (are these the bell housing to engine bolts?)
the last point seems to be my problem. the 97 d-90 workshop manual says to remove 6 bellhousing to engine bolts as the last step before being able to seperate the engine from the trany. i count 8 bolts. am I confusing the bell housing bolts for something else?
Let me know what I'm leaving out.
thanks
could the bell hosuing be siezed to the transmission?
i'm not sure i would know what to look for if they were seized together.
how would i know?
and how would i disconnect them?
i didn't take off the starter motor. does the starter motor bolt run through the engine housing and into the bell housing holding the two together?
may be my answer...
not sure on the 97 auto but on the 95 manual it does. and my guess would be that it does.just pulled mine apart last night
1 - 5 of 5 Posts
