1 - 10 of 10 Posts
Have you tried Folex upholstery cleaner? Seem so get a lot of stuff out. Option B would be to find someone with an upholstery extractor. Just had the headliner on my 4Runner done and it looks great.
I have Genuine headliner material available, complete for 90 or 110. Individual panels are available as well for either of your 3 roof panels, or the rear finisher above the tail door.
I work at an auto dealership and we use crazy clean (made by sprayway). The name makes it sound silly but it's a serious cleaner. I've gotten plenty of grease and water stains off of headliners with this by spraying this on a cloth then blotting and rubbing it on the headliners. Ace hardware carries it in my area.
‘91 110
Thank you will try it out!
‘91 110
After you have tried the above and have a compressor, pick up any air powered cleaning gun on Amazon - about $50.
I continue to be amazed by that little tool - it saved me from replacing several headliners and, it works on fabric upholstery and many other items that need cleaning. I believe you will be impressed and, most professional detailers use it as their go to cleaner (that is how I learned about it).
‘91 110
Discussion Starter · #8 ·
Thank you. Does a cleaner or anything go into it?
Yes or no - your choice. I had a rust-stained headliner from a leaking skylight which I did not consider salvageable ==so, I used one of these (with water only-no cleaner)) for the first time and the rust stains came right out.
Check out some YouTube videos to get an idea of what type stains might require something, like a few drops of Dawn, be added.
‘91 110
Discussion Starter · #10 ·
Thank you so much for this recommendation. It was the first thing that I tried and I don’t have to use anything else. It worked a miracle
1 - 10 of 10 Posts
