1 - 2 of 2 Posts
I have (2) new Exmoor jump seats ready to bolt down. Having trouble deciphering the best location in the wheel wells to drill for the belt bolts (OEM belts, non-retractable) I understand the whole reinforcing issue or lack thereof in a Soft Top. I'm just looking for the most ergonomic or traditional location to attach.
Subscribed. I mounted the seats where they lined up with the rivnuts on the capping (or whatever that piece is right below the window).
I haven't however mounted seatbelts because I don't have a plan to make it reasonably secure.
I am certainly not going to drill a hole in the aluminum and put washers on either side of the seat belt bracket... and I don't think I'm going to make a big L bracket to get steel to steel all the way down to the frame. I'm guessing there is a solution in the middle that would do the trick.
Good luck.
1 - 2 of 2 Posts
