1 - 20 of 49 Posts
I have a Series III 109 with a 2.25 L NA three bearing in it and of course he's as pokey as a turtle. I'd like to get him where I can get him to 55 easily on Overseas Highway. The engine is great actually but I'm tired of one finger salutes. Any advice? 200 TDI? 300? Is my current engine worth anything in a swap?
Thanks.
Thinking that overdrive will be the ticket. I don't want to spend a mint (this truck is a pure toy and won't be restored (I already made that mistake with another vehicle and was afraid to take it off road). My soon to be 16 yo wants to drive it because his friends think it's cool - another reason not to restore him as he might end up in a few scrapes.
I was somewhat in your situation late last year and I'm currently going through the swap process. I started by buying an engine, trans and tcase to replace an original 2.5na drive train. My "plan", based primarily on what I had read up on, asked around and observed from other's stories, was to simply pull the old and do a straightforward bolt-in install. The reality, which is tough to see when you are wrapped up in all the bromance, is these are old lumps, there are no guarantees so it feels a shame not to refresh many many things before it goes back in. Nobody will be holding a gun to your head to replace stuff but if you don't you might just shoot yourself later. Using nice round numbers, if $10k is a number you're comfortable with then you should do it and if you blow the budget by 10%-20% just drive it more and enjoy it longer.
Clay
Discussion Starter · #12 ·
Part of my fears... I may just continue to tick everyone off then. Overseas highway is a parking lot on the weekends anyway. Not going anywhere very fast.
------ Follow up post added July 11th, 2015 10:11 AM ------
Uncle Douglas, what should I drop in him? I'm totally against going petrol.
The overdrive isn't going to give you more power, only lower engine rpm at any given speed. It's not going to help acceleration or maintaining a speed after you eventually get there as your limiting factor will be the power available from a na diesel engine.
The lesser expensive option is likely going to be fitting a 2.25/2.5 gasoline engine with a little more cam and more carb, but as you mentioned you are not fond of gasoline... I guess that leaves you with fitting a 200TDi!
Apologies if i gave you bad advice about the OD. I only have experience with the gas 2.25l and an overdrive made a big difference if you want to cruise at 55-60mph without trying to push the gas pedal through the floor. I stand by the sticker recommendation though!
1 - 20 of 49 Posts
