87 defender 110, England import, switched from right to left drive. Steers great 95% of the time
but if u hit a bump, while braking the steering wheel shakes violently. Replaced steering damper
didnt help. Whats Next ??
Steering damper is the wrong place to start!
1. Hub swivel tension ... How To Adjust Your Swivel Pin Preload - Land Rover Forums - Land Rover Enthusiast Forum
2. track rod and steering rod ends ... check for wear ... they are cheap to change
3. bushes - check with big pry bar
4. shock absorber - if they are worn it can lead to steering shake
Reactions: cappy
Check your pan hard rod bushings and the rest of them. Old truck. Probably old bushings.
Swivel preload could cause it also; however, it is the most complicated . Check your bushings first.
Panhard Rod Bushings (and bolts)
Steering box bolts may have loosened
Regardless of the symptom, always, always check or just blindly replace the rear link - chassis bushings.
pan hard rod bushings or bolts ,,,, please let us know the result....
After doing everything else, mine was swivel preload. I second LeastOnce completely.
