1 - 8 of 8 Posts
· Registered
Hey everyone,
I'm getting ready to install a Rover V8 4.0 into my 71 Series IIa. Will also be installing an R380 & LT230, P38 power steering and D1 axles. Will the V8 4.0 bellhousing work or will it be too long? Any help would be greatly appreciated.
Thanks, Bob
· Premium Member
What r380 do you have ? If you are asking if the auto v8 bellhousing works , it will not. You need a v8 bellhousing made for v8 r380. There used to be or might still be aftermarket options to use different r380 with aftermarket bell housing to the v8.
· Registered
The V8 4.0, R380 & LT230 are out of a D1. I’m trying to determine if the entire setup will be too long for a IIa 109.
· Premium Member
Are you planning on converting the shifter to defender style? If so it can fit. I did one on a 88. 4.0 gems, defender r380, lt230. I did switch the front cover to a gems p38 to make the front of the motor slimmer. Transmission tunnel and bulkhead were also modified.
1 - 8 of 8 Posts
