1 - 18 of 18 Posts
Front and rear out of a 109 Canadian military truck (lhd). No idea about condition. Only rolled in and out of my garage. Front cv boots are shot.
Includes from the pinion flange to the hubs and leaf springs Drag links and everything.
Let's do $400 for the set and $50 if you want the driveshafts.
Located in 07701. Will not ship.
Note rear is still under the tub but can have it out by next weekend.
Discussion Starter · #2 ·
EDIT: thats weird, it wont display the quote. "Front cv boots are shot." What do you mean by this? Also, are there locking hubs on the font, and if so, what kind? -Jeff
See this pic
There are like rubber boots/sleeve where the cv is just outside the end of the axle tube and they are deteriorated.
Yes it has locking hubs in front. No idea what kind. If you have something you want me to take a pic of or look for just lmk
If you want to learn more about the free wheel hubs you should look up Ike's webpage on rover locking hubs.
Yes the part you turn is plastic
Ok thanks though! Learned something about them lol
Also Series axles don't have CV joints, they're single cardan u-joints.
If original military the front should have a reinforced tube.
Discussion Starter · #8 ·
yes the front tube is re-enforced (looks like a piece of angle iron welded to the bottom.
Excuse my poor terminology, it was the first thing that came to mind when I wanted to say "the turny part"
Also i believe these are the type where you can bolt the leaf springs to either the top or bottom of the tube, so you can either have a raised or lowered vehicle pretty easily.
Ha, NP. "Swivel housing" would work too. :tounge
The gaiters are really to protect the swivel balls from pitting from impacts, like sand and gravel, and also to prevent snow and ice in the winter from building up and taking out your swivel seals.
The flat spot on the top of the axle housing is for hitting the bump stop(the rubber thingy on the bottom of the frame). First Series vehicle? Big learning curve! A parts book can help as it is important when asking who has what for doing repairs, you don't want to buy a dohicky when you wanted a whatchmacallit.......
Discussion Starter · #11 ·
haha - yes first series truck, that's why im putting a coiler suspension and disco axles in it... so I know WTF im doing
I thought you could put the leafs on the top of these though and get another 1-2" from that alone.
Wow if you can get that I'll be impressed. Especially when the condition is indicated as unknown. Good luck with your sale!
You can do leaf over axle as a mod to the suspension. There are a few series trucks around the forum that have that set up. Pros and cons like everything else. ;)
1 - 18 of 18 Posts
