1 - 3 of 3 Posts
Does anyone know what kind of electrical connector this is? It has the number 35260-2 on it.
It came with my new @exmoortrim seat belts, but it is not a match for the cable used in the 1995 NAS Defender (picture 3).
If I jumper across the two incompatible adaptors, I get correct warning tone behavior, so this seems to just be a connector issue.
I’d like to find the correct connector so I can update my wiring harness to match whatever this modern connector is. Any ideas?
seat belt unbuckle warning chime perhaps. also seat heater comes to mind
I have since learned that the original NAS harness is a 2-pin SAE connector.
I ended up just buying a trailer hitch extension cable with the correct 2-pin SAE connectors for a couple of dollars, clipping off Exmoor Trim’s mystery connector, and wiring in the SAE connector. Now I can just plug into my existing harness and everything works properly.
1 - 3 of 3 Posts
