1 - 5 of 5 Posts
Hello all, I have an A/C system like the 93 NAS 110. I think my Evaporator is leaking. I can't find a leak anywhere else and I have to keep adding Freon. I know the evaporator is NLA, have any of you found an alternative? Yes, I have thought about ripping the whole thing out and going with a Ministry of Defender one. ministryofdefender.co.uk/
448548
To my knowledge all these parts are NLS.
An alternate would be to remove all the upper dash unit and replace it with an under dash unit.
Yeah I get that, but I do like my legroom. I may try to retrofit something around the same size. Maybe a place like Compressor Warehouse can come up with an alternative. I found a blower motor, so I suppose I could find an evaporator.
some time ago I came across similar issue on a toyota, a radiator shop was able to find and repair leak with tig welder.
it may behoove you to try.
That would be my first choice. Pull the evaporator, see if it really leaking and see if it can be repaired. Have you used UV dye to look for leaks?
1 - 5 of 5 Posts
