This is on a 1985 90. So, I am putting my front differential back together and was almost done but when I put the hub assembly back on and when I tightened it down the bolts on the hub and the bolts on the stub axle hit each other. Weird. I did replace the bearings and races in the hub. Timken bearing and races with both the same part number from RN. Thoughts?
