1 - 10 of 10 Posts
Hi everyone
I purchased a R380 transmission from Ashcroft. I recently flushed the fluid after driving about 2500 miles and the results left me worried. The bolt had a lot of shavings of metal and the transmission oil was completely black and I noticed a milky wave as well as other small pieces of metal in the oil. I have attached pictures below: is this normal? Should I be worried?
What oil did you put in it?
The MTL should have been fine. I would flush the box a few times and then get some miles on it and see. Is it shifting okay?
Discussion Starter #8
It shifts a lot smoother with the dexrion iii atf that I just put in
Discussion Starter #9
Discussion Starter #10
Also have noticed less vibration in the shifter as well
1 - 10 of 10 Posts
