1 - 4 of 4 Posts
So a couple quick questions:
I got a set of D1 axle assemblies I plan on using in my series coil build. I won't be running ABS. Any reason why i should put the ABS rings back inside the rear rotor hats? Other than i guess having some open holes if don't?
I did not replace the reluctor rings on my rear 24 spline swap and have suffered no ill effects. The rear stubs/hubs were taken from a D1 axle as well. The new rotors have been fine without the rings.
Thanks. That's was I figured but just wanted to make sure. I couldn't see there being an issue
Prob going to keep the dust shields off as well. All they are good for is trapping mud rocks and sticks from my experience
Thanks. That's was I figured but just wanted to make sure. I couldn't see there being an issue Prob going to keep the dust shields off as well. All they are good for is trapping mud rocks and sticks from my experience
I kept both off when I built mine up.
1 - 4 of 4 Posts
