Hello some help is greatly appreciated before I mess it up even more.
I was attempting to change the rear flange gasket on my 110 since it was leaking. Took the bolts out of the flange but had a hard time removing the flange. I removed the clip to try and take the half shaft out to get some leverage but still it would move. I then had the great idea of removing the tire and in doing so, the flange came loose but pushed the half shaft in and now I can't pull the half shaft out.
Tried a vice plier and I could feel it move like 5mm ( a little bit of play) but it doesn’t want to come out.
Any suggestions. I did a search and tried raising the other side and moving the wheels but that didn’t work.
Thanks in advanced.
Thanks in advanced.
