1 - 5 of 5 Posts
Hi there,
I just got the security code for my defender radio which had stopped working post battery disconnection .....input the numbers and pressed "5" as per all the notes I read on other forums to accept the code - but nothing happened! The screen just said "code" and the numbers I inputted.
Any ideas on what to try next?
Many thanks for any help you can give.
:whistling:
Do you hear a "beep" each time you enter a number? I had the same issue with my RRC radio and no beep while i was entering the code.. ended up replacing it.
Assuming you have the correct code and are entering it correctly...
Keep entering the number sequence until you hear a beep, then stop no matter where you are in the sequence and start over.
Reactions: fleur
thanks for the replies, Im in the UK so will try a landrover dealer maybe next. Haven't had any beeps when Ive put the code in.....
will keep :whistling:
1 - 5 of 5 Posts
