There are a couple of products that give you a water resistant coating on the board itself.. as well as clean water damage corrosion. It does work as long as nothing is burnt out on the PCB.
Definitely not a waterproof case however,.,, but It is hydrophobic coating applied directly to the PCB.
I'll be offering it as a service along with the Chips I am selling.
Other than that, their use to be a company in England that sold an extension harness for the Engine wiring to ECU, it was about 2' Long if I remember correctly with the idea being you mounted it to the roll cage. This was for the trials trucks.. But I have not seen that in a long time.
other than that I'd bring a 2nd ECU... and swap it in if needed.. take the submerged one apart and let it dry out... They are pretty robust.
they have issues when corrosion sets into the contacts on the PCB
