1 - 10 of 10 Posts
I noticed tonight that when I depress the brake pedal my parking lights and my brake lights turn on. Intermittently it seems like the brake lights will start working as they should - only when the pedal is depressed. I verified that the ground on the battery is good, clean and tight.
The issue presented itself when I installed leds around the truck. I thought they might be the culprit so I changed back to incandescent bulbs and the issue above still persists.
What am I missing? Is it the brake pedal switch?
Most likely a bad ground at one of the lights. It feeds power back through the ground via the parking lights as they share a ground connection. Check the grounds at the rear lights first and make sure they are well connected to the body.
Yup. That's what it does. Always thought it was strange to light up just the once so I thought something was a miss. When towing, it would blink as you described, so figured it was fine and maybe just a bit glitchy.
1 - 10 of 10 Posts
