My 1972 Series 3 2.25 petrol engine seems to overheat. The gauge moves slowly but constantly into the red within a mile of driving. I changed the water pump first. Didn't help. Then changed the thermostat, didn't help. Then changed the water temp sensor, you guessed it, also didn't help. And finally had the radiator cleaned. Also no effect. Coolant level is as it should be of course. That would have been the easiest. There is no leak as far as I can tell.
The pipe from the thermostat to the radiator gets hot (picture 5862). The pipe on the bottom of the radiator stays cold (picture 5863). So I'm guessing the radiator is blocked or no water is flowing (water pump ?). But the radiator guy filled it with water and said it had a good flow. Maybe the pump I installed was defect. Got it from Rovers North. I tested the thermostat on the stove in a pot of water and it opens at 160F as it should. Also the top pipe couldn't get hot if the thermostat wouldn't open. I turn on the heater and the pipes to the heater get warm too. There just doesn't seem to be a flow through the radiator. Maybe I need to double check that the water pump is working correctly. How can I test the water pump ? Could the gauge be broken. My neighbor has a laser thermometer. Any idea what the temperature at the block should be ? or where I should measure. But it worries me that the pipe on the bottom of the radiator is not getting warm. While the pipe on top is getting hot.
Anyone has any other ideas ? Attached a couple of pictures if that helps.
Thank you
Frank
Thank you
Frank
