The question is for those with experience using a Roverdrive overdrive (the mechanical Canadian units) in a D110.
Will the overdrive work well in a D110 with 33 inch tires on long trips along flat roads or will it be overgeared?
My engine is a slightly tuned 2.8TGV engine.
I currently run 1.22:1 Discovery gears in my transfer box with 32 inch tires (265/75/16) and it is sort of OK but I will need to use my truck in the mountains more in the future and the gearing is "too long" for that kind of terrain. I will therefore go back to the original Defender gears and probably install an overdrive for long journies on flat roads but the question is: can I go to 33 inch tires (285/75/16) or will it be too much for when using the overdrive?
Your opinions will be much appreciated.
Cheers
SANTIAGO
Cheers
SANTIAGO
