1 - 20 of 55 Posts
Ok, this question has probably been asked 100 times (or more) on this site, but I can't seem to find a thread that fully addresses my question.
I just purchased a 1994 ST with the stock 3.9 V8 and a r380 trans.
Can this machine have the gearing reworked to go slightly faster? It cruises along nicely at 55 mph with about 2700 on the tach. It will go faster, but candidly I'm not sure what rpm level that I should stay at/under.
I know, I know, I know...I'm asking a tractor go 65 mph...it would just be really nice if I could make that happen.
If the gearing can be reworked, what does it take to do it, and what's a ballpark $$ figure I should prepare myself for?
That is not a gearing issue. It is a power issue. You should be able to do 90. The engine needs work.
Second that, also are you rolling on stock tires?
3000 rpm at 70 mph is normal... You don't want to go faster than that on a short tall vehicle.
We need an FAQ for road testing defenders. A V8 should pull hard to 80 and start to taper off and drive stable and smooth.
Discussion Starter · #8 ·
Good point about the vibration at higher speeds. I'm gong to attack the engine/power issue first. Then determine if I want to take the lift down, or back to stock.
I'm going to check the typical tune-up type items, but I don't that is going to explain my power issue.
The engine doesn't display any other issues besides top end speed (55+)...it sounds fine, drives fine. Any thoughts from the group on where to start diagnosing the engine/power issue? (Assume that I know very little about wrenching on engines...because it's true)
If it is not tuning, it is most likely the timing chain or cam. The chains always stretch and kill power.
It has nothing to do with gearing if he is only doing 55. Maybe the speedo is a bit out, but I'm pretty sure he would know if he was doing 90....
I second Red90's input on the timing set. I rebuilt my engine due to poor performance and the only real issue I found was a very worn timing chain (not a fan of nylon timing gears). Its a pain to pull the timing cover, but it could solve your engine performance problem. I put a Kent cam and a Cloyes timing set in and have had no worries.
Angus
Discussion Starter · #18 ·
Guys - thank you for all of the tips/ideas. Very much appreciated!
I spent some time going through the plugs, wires, hose to the MAF, etc. Everything checked out. I did not investigate the timing chain given the time involved in that fix.
I took it back out for a road test and got it up to 65 and 70 mph (still had power to go faster, but not necessary to do so). I was running about 3100 rpm at 65 mph and about 3200 rpm at 70 mph.
Does that seem reasonable? (keep in mind I'm running tires that are 285/75/16)
It seemed ok to me given that in this thread Carlos mentioned 3000 rpm at 70 mph was about normal.
Are you checking the actual speed by GPS or are you believing the speedometer?
There is a gearing calculator on Ashcroft's site that you can check on.
Discussion Starter · #20 ·
Had to work off the speedo today but my GPS was giving me the business. I think I'm pretty close on the speed based on how traffic was traveling and what the prior owner told me about the accuracy of the speedo.
Just got my GPS updated a few minutes ago, so I'm going to drive it again to verify the speed. Thanks for the tip on the Ashcroft site!
1 - 20 of 55 Posts
