1 - 1 of 1 Posts
Model: 1992 Discovery ‘Dino’ 5 door
Contact: [email protected]
Modifications:
Engine:
Stock 3.5 V8i
Jacob Electronics Energy Coil & Wire set
Splitfire Spark plugs
K&N air filter
ARB Safari Snorkel
Electrical:
Upgraded 80 Ah alternator
Optima Yellow Top battery
Complete wiring & location for second battery
Hella emergency electrical kill switch
Waytek Wire Inc. switches
Control Switch for stock electrical fans
12v output in the trunk & in the engine compartment
2 Hella FF100 fog lights on front Bull-bar
4 Hella FF300 Driving Lights on Roof (To Be Installed)
Work-light on rear ladder
Hella cut-off switch for front winch
Drive Train:
Series 4.7 R&P
Rear RD56 ARB locker
Rear LR HD 24 spline axles
ARB compressor in trunk
Paragon Performance SS brake lines
Breather lines for all components extended to snorkel top
Suspension:
OME front 764s with N73 shocks
OME rear 762s & ¾ aluminum spacer with N76 shocks, custom bottom shock mounts, RTE cones, EE bottom retainers, and custom rear kinked/lengthened trailing arm
Polybush ‘Blue’ bushes all round
Custom Steering dampener relocation
OME steering dampener (SD22)
Custom reinforced steering rod (34mm in diameter, 6mm in thickness)
Dodge series 600 ball joints (twice the size of the Rover ones at ½ the price)
RTE 2” Body Lift
Rangie Spares Fiberglass extended flares
Protection:
Front custom pre-runner/winch bar
Front and rear SG diff guards
Rear custom winch mount (To Be Installed)
Rear custom bumper (To Be Installed)
3” round tubing rock sliders (To Be Installed)
Custom internal roll-cage (To Be Installed)
4 bucket seats bolted to cage (To Be Installed)
Internal mount for spare tire
Accessories:
Warn M8274-50 Winch with:
Master line 3/8”x100’ winch rope
Spidertrax aluminum fairlead
Rear Ramsey RE10 winch (To Be Installed) with:
11,000 Pull-Pal (Custom made 8mm shovel – original bent)
2 Waffles
Massive tool/spare part box in the rear
48” Hi-Lift jack with Jack Mate
ARB recovery bag with all the necessary equipment
Full First Aid Kit in Pelican 1300
Magellan ProTrek Color GPS
Motorola FRS & Radio
Gerber Ax
SS with plastic handle shovel
Internal roof net
Bulky Spare parts under rear seats
Map light above passenger visor
Rear ladder
Rear NATO hitch
2 Front SMBs
2 Mag Lights
Waterproof seat covers
2Kg Fire Extinguisher under driver’s seat
Mat Black Hood
Rear Fenders totally chopped
Tires & Wheels:
15x8 Steelies
35x10.5x15 Simex Extreme Trekkers
<br></br>
1 - 1 of 1 Posts
