Most don't swing away, but do at least offer a ramp.
Thanks. My ROW does not have a 2” receiver it has the OEM 3 pt hitch. Is there an aftermarket 2” receiver replacement that maintains similar tongue weight specs as the original hitch?
That's sharp. ThanksNot sure how you would build a swing-away that would be carrying 400+ lbs.
I had a motojack rack on my 90 that slid into the hitch. Worked fantastic, easy to operate and most of all, easy to load a bike on. You just need that 2" receiver.
View attachment 455852MotoJackRack.com - Get Carried Away With Dirt Bike Racks
Get Carried Away With Dirt Bike Racksmotojackrack.com
WOW That's slick! Some big torsional strength for sure. Happy to see some orange.That's sharp. Thanks
I'm looking for access to the back door, as I'm working on an overlander build, so that set-up probably won't work.
RakAttach (see below) makes a solid product, I don't know the max weight, but I think it's 300#. I have an email into them. I would still need to convert to a 2" receiver, unfortunately.
Does anyone know if the class 3 hitch sold by Rovers North have the same Tongue rating as the OEM hitch? How about the step bumper? Is that rated similarly?
thx
Thanks for this. Will call TerraFirma on specs.![]()
TF873 - Tow Receiver Assembly by Terrafirma - Defender | LR Parts
Due to the Covid-19 outbreak LR Centre are experiencing certain supply issues and are unable to offer these items on our usual 1-2 working day order time. We expect any orders for these parts to take at least a couple of weeks to fulfil although we can not be sure due to current uncertaintieswww.lrparts.net
This is the one I have while it's a bitch to fit on a 110 due to the rear fuel tank, it's substantial.
It's all about the depth of the hitch receiver with any of these products. This one is about four and a half inches deep. The Wilco/ rack attack all those things all require a pretty deep receiver
Okay, thanks. Does anyone know if the terrafirma receiver above has a higher capacity than a NAS bumper style class III receiver, or the other bolt-on class III receiver Rovers North sells on their website?It's not rated fyi. I can give you measurements off mine if you need it.
Who makes the m/c rack in the photo?That's sharp. Thanks I'm looking for access to the back door, as I'm working on an overlander build, so that set-up probably won't work. RakAttach (see below) makes a solid product, I don't know the max weight, but I think it's 300#. I have an email into them. I would still need to convert to a 2" receiver, unfortunately. Does anyone know if the class 3 hitch sold by Rovers North have the same Tongue rating as the OEM hitch? How about the step bumper? Is that rated similarly? thx View attachment 455854
