On these mounts, with the angle of the mounts being rigid and parallel with each other redirect the force into the pads, not lateral sheer, and as they compress. This "sandwich" of rubber will work more as a sheet/volume in unison. The two vectors of force acting routinely on the pads are actually in and out, pulling, pushing as the engine twists during acceleration and starting. That will break down the pads. It's designed to be that way and as such, it does a decent job. It is still rubber (or rubber and oil, or synthetic) and the closer to heat (exhaust), the more it will crack, harden and brake down, so protect them. And remember, it is a consumable item just like a suspension bushing. Its why I really wanted my engine be easy to change in case of failure or age. If you struggle to get an engine in, you'll struggle to get a pad out. I want to be able to lift the engine just high enough to get the mounts out with everything but the bonnet and turbo hoses still connected, if possible. In my case I need to disconnect the fuel feed to, but I am working on a solution for that...
