1 - 2 of 2 Posts
This is an extremely capable rig that I have brought everywhere. This truck is also rare being it is a Kalahari edition SD with no sun roofs to worry about leaking and messing up the headliner... Also only 115k miles
Modifications:
RTE Front bumper
Rock Sliders
RTE 3" lift
Rancho extra long droop shocks for 5" of droop
RTE loop to loop shock conversion for high articulation and droop to keep all the wheels on the ground at all times to help get you through anything.
RTE Rear shock relocation hangers
Detroit TruTrac in the rear
Upgraded drive shaft in rear
Safari snorkel with custom filter ( tested to 6' of water)
Dual battery setup with battery isolators ready for your winch
Differential breather kit made for deep water
255/85/16 BFG KM2's
Built in and hidden power inverter
The New:
Radiator ( best money can buy... Only 500 miles on it)
Water pump
Fan
Fan clutch
Rebuilt transmission ( spent $2k on this) only one year on this
New rear ball joint
Brake pads
All electrics are dielectric greased and or completely sealed
All new seats except driver seat
New wheel bearings
New motor mounts
Front driveshaft was replaced
The bad:
Transfer case is noisy but works as it should
Brakes probably need to be bleeding
Driver seat is torn
Has typical Rover leaks
Has a little exhaust leak
Rear bumper is bent up. (Can get another if a must)
Go to my YouTube channel to checkout what this truck can do:
https://m.youtube.com/channel/UC17vExQcmqi-8oUAkDpPMpA
To see some pictures go to the Craigslist link:
https://houston.craigslist.org/cto/5099323867.html
I do have a roof rack for sell if you are interested in that too.
The reason I am selling my truck is bc I picked up another Rover with a lot more mods so it was easier to just to keep the new truck and sell this one off. Some of you might have seen this truck at SCARR ( South Central Area Rover Rally) this year. I always drive this rig wherever I go; off road hard and then drive it back. This truck will not disappoint. $5,500 OBO Cody 832-533-5134
1 - 2 of 2 Posts
