1 - 9 of 9 Posts
I had a corroded connector creating the HDC/Transmission fault special programs off, etc. This is the problem that is created by a bad brake light switch, wrong bulbs, bad splice, or corroded connectors. I was able to find the proper Tyco AMP TE connectivity connector and have a few extras if anyone is in needs them.
$20 shipped conus for the following
1 each of part # 6-1419167-1 8x2 male connector
16 each of part # 2-1419158-5 male pins
1 each of part # 9-1419170-1 8x2 female connector
16 each of part # 1393366-1 female pins
i didn't feel like counting out all the pins so the pic just shows 1 each on the contacts.
Can I ask where this connector is?
Thanks
So did you fix your front sunroof drain as well?
that's next. drives side drain is broken at the elbow. pass side looks fine so will be checking for leaks at the A piller. Just need to get home while there's still daylight. May wait until this weekend to square that away.
1 - 9 of 9 Posts
